Slow Train
Member
A couple for the collective.
1. If a coach side has turnunder do you allow extra material to cope with the curve when drawing the side as a flat drawing?
2. If a coach body has turnunder on both the sides and ends what curve does the corner join describe when the ends and sides are flattened out?
I’m trying to learn 2d and haven’t even looked at 3d cad hence the question.
I guess the answer in 4mm and below is probably 2 strokes of a 6 cut file and forget about it but what about the larger scales such as G3?
Ralph
Ralph
