davey4270
STOP PRESS just in case anyone is following this build closely. I forgot to fit the cylinder drain cock operating brackets.
This little etching was folded up and fortunately the superglued in drain cocks came away with a gentle twist with a pliers. It is simply held in place by the drain cocks which pass through the etched holes. Unfortunately, one of these whose mounting spigot had been shortened to fit was too short and was replaced by a spare.
This cylinder assembly has been Araldited in position, but I have not fixed the slide bar support bracket to the frames in case some minor adjustment is necessary.
I also added the footplate support brackets which I had previously overlooked. These align directly underneath the rear tank support brackets.
