Compton castle
Wiltshire Wisdom!! Can't beat it !!
Ozzy, that's correct the Up and Down carriage sheds just outside the station and the bottom of Camden bank but no loco facilities there, nearest is Camden shed at the top of the bank just before you plunge into Primrose Hill tunnel.
I've bumped this just in case any one missed it on the previous page.http://paulbartlett.zenfolio.com/gwrtankwagon/h200fbfe3#h314439df
Here's a link to a converted road rail tank wagon I'm having scratch built, it was converted to carry diesel oil. I have a picture of it at Ranelagh bridge.
It's tucked behind D1000.
They lasted until the late 80's. It could have been seen at steam sheds or stabling points before refuelling points where installed. Or later at DMU stabling points or small diesel stabling points providing a top up if needed. Other than that it's quite an interesting looking wagon.
There is a chance this might appear as a RTR project from JLTRT, any one interested ?? I'm not sure of a price just yet.
65 foot tables on the western, same as at RB you could squeeze a duchess on there, myself and Ozzy have checked you know just in case one does make a visit!!
I did look at landore, Shrewsbury is quite interesting or if you just want something set around a turn table weston super mare is a good one.
Electric blue AC electrics and dirty steam locos would look great, based somewhere around rugby could work.
Ooh that would be great, I'd love to see them.
Steve
Should only be half a like on that one!!I'm guessing the '48 trials locos might have visited Ranelagh Bridge, but I suspect it was more likely they were serviced at OOC; that way you'd get away with some proper engines...
Coat, hat, door...
Steph
Going back to Princess Royals and the later Princess Coronations with regards to GWR heritage. both classes utilise the same arrangement for driving the inside valves via rocking arms from the outside, ala Kings and Castles.
Additionally, 6200 & 6201 have an inside motion bracket to support the outside slidebars, a direct copy of Kings and Castles, 6204 onward had the standard Stanier outside mounted slide bar bracket except 6205 which had the monsterous Y bracket.
...I used to work in London and travelled via Euston every day for a number of years in the late 60s and through the 70s, then worked in London again for three or four years around 2000. It's been fascinating to watch the infrastructure change over the period.
Brian
A) on the Friday run by sitting on the toilet seat in the Mk3 coaches, removing the washdown plug and observing the wildly oscillating wheel immediately below. This gave me a good insight into the workings of the tyre / track interface - anyone who thinks the wheel runs in a reasonably straight line is very much misinformed. It also made me appreciate good bogie / suspension design, as all that flailing about was well contained within the bogie and never reached the body of the coach.
No I did not have a ticket…………….
I had a BR All Routes pass.![]()
If you had an all routes pass, why put it in small letters?
