Rapido SECR Van
A simple (ahem) bit of regauging to start the year. Three victims here, the first is the lovely Rapido SECR brakevan, more on the other two later.
Happily, the engineers had a few of these and Ted West photographed one at Axminster in the early ‘60s, and with the minimum of alteration - a vac' pipe strung along the solebar and a new number - a handsome addition to my PWay fleet will result. I have had one on the shelf looking reproachfully because I wasn’t sure what to do about the fully modelled brake rigging. The axles, I’m happy to report, are the standard length allowing a simple drop in of Gibson wheels running merrily in proper brass bearings.
As you ought to be able to work out, the brake mouldings are a positive fit (see those 'T' shapes on the floor, above) secured with glue. Actually quite good design, allowing tricky details to be mass produced consistently if a bit of a problem for those of us in EM. We're not the main bit of the market, of course, so have to live with that and the brakeshoes can be extracted, though those on the end put up a fight, I haven't actually broken anything critical! It should be apparent that one side had a bit more glue than the other...
So the plan of campaign is to drill out the brake yoke locations at 0.5mm for wire, perhaps reusing the end yokes, adjust the fit of the shoes and then the small matter of vac' pipe, couplings, and so on to taste.
