Lovely curves!
Oooooh. Hell-lo. Venus di Milo?
Lovely curves!
Sorry if I've missed this but did you mention a spec. and supplier for the Cable Tray? Having looked at the various options for my garden I think your solution will be best for most of the areas away from the house and outbuildings.
Andrew
Hi Andrew,
My cable trays came from DP Building Systems. 3 metres long, 225mm wide, medium duty.
Unistrut Medium Duty Cable Tray 225MM X3M Pre-Galvanised (TUMLT225/10PG) Medium Duty Cable tray comes in different heights : 24, 48, 72, 96 mm Cable tray comes in different heights : 24, 48, 72, 96 mm
Any right thinking neighbour would surely now want one of their own.
The problem is the raised beds. We hoped we would either a) be above them, or b) just be inside them. In truth we expected to hit them, and are only about 6 '' out from where the original survey placed the boards. After discussion with the garden management committee (of 1 ), it has been established that we can leave the bottom poles in situ, and then cut the interfering parts of the 2 top poles off. We have to finish the resultant triangle off with one of the cut-off sections so it looks nice. All sounds fine......It's not, as bolted on the inside, and sure to be in the way, are brackets holding the upper and lower poles together and staking them to the ground. So a lot of work ahead tomorrow
That must be nearly the full circuit now?
JB.
