Rob Pulham
While modelling this morning I found myself in need of an Allen 'Screwdriver' Now I know that you can buy them, in fact I have had a set on watch on eBay, for several years. But I haven't actually got around to buying them.
I have an old tobacco tin that I inherited when my neighbour passed away in which I keep my Slaters wheel Allen keys and a slightly bigger size that fits the grub screw on the former SanCheng/Finescale brass motor gearboxes. In the tin where a couple of my neighbour's 'worn out/bent ones that he had kept.
I also had a short length of brass bar which has a slight bend in it. The bend isn't visible but it doesn't run true if I pop it in the lathe.
Making use of one of the old Allen keys and the length of bar I made an Allen Screwdriver.
I used a slitting disk to chop off the L leg of the Allen key and to square up the other end again. Then I made a handle from the length of brass bar not worrying too much that the turning wasn't quite concentric.
The Allen Key end has a slight bend in it too but it works fine and I hope to be using it for years to come.
