7mm 33/1 a Lima conversion
Ian G
This is how I did mine very photo intensive.
The basic strip down
A bit of time with a fibre scratch brush
The chassis had a large amount of plastic removed, angle brass around the edge and cross members, some fittings added and the fuel tank molding filled with lead
More to follow
Ian G
Ian G
The underside of the chassis, I am using a JLTRT buckeye coupling in the dropped position.
some fittings in place
Westdale/PRMRP/MMP fittings, the vac hose I replaced with a fine spring.
Buckeye temp fitted, the screw that secures the coupling also secures the chassis to the body.
Ian G
Ian G
Fitting out the body big square bits for the sides, horn covers and grill, the mesh was replaced with one from MMP
apologies for poor photos this was before I had a better camera
all soldered together
and some dry fitted
jhockuk
Thanks Ian, they are very helpful to my build.
I really like the pic of the completed model on my post, a do like the 'dutch' paint job.
Ian G
Brian looking at my old thread on RMweb I started this in December 2008, I have spent most of the time building wagons.
The fuel tanks I left on and filled the cavities with lead.
Ian G
Steph Dale
Blimey, Ian, I like that a lot!
Is that a straight PRMRP+Lima build?
I must admit that when I see results like that I'd be tempted to have a go myself...
Steph
Ian G
The 1st 33 was Lima with PRMRP detailing kit, then extras from MMP, the hardest thing to find is the right sized fittings as the white metal castings are to large for smaller fittings. I have made the bogie frames removable so I can strip down the bogies for maintenance.
Ian G
