Medite Tricoya - for discussion
Rob Pulham
I thought that since it seems to have generated a little interest I would create a thread for discussion of it's merits.
As requested by Richard I have put some offcuts in a bucket of water and another untreated piece just out to see how it fares - as it happens on that score Chris had taken a bit to stop soil from dropping through into next doors garden.
Complete with snail!
I will post some more shots a in couple of weeks and then leave them soaking until I need to bucket for something else.
Dikitriki
Excellent Rob
Very useful tests I think. If we could refine the 'bucket test', once it has had a couple of weeks, can you let it dry out thoroughly, see if there is any impairment, and then put it back in the bucket for another soaking.
Rob Pulham
Excellent Rob
No problem:thumbs:
Rob Pulham
I have moved this thread to 'Gardeners World' which can be found in 'Resources' on the Forums index page:)
Thanks Phill,
Well what do you know, an entire section of the forum that I didn't know existed:rolleyes: - I have read a lot of the threads but from the What's new? shortcut.....
Rob Pulham
A small update, the first two weeks of soaking have passed, Chris has taken both pieces out of the water and put them in the green house to dry off.
I will leave them a couple of weeks to dry then take another photo of them but at the moment they look unchanged.:thumbs:
Dikitriki
Hi Rob
Can you put a vernier on both pieces and one of your undunked treated pieces, and measure the thickness of each please?
lancer1027
Sounds like the Tricoya is living up to its status......................so far.
I will be monitoring this thread :thumbs:
Rob:)
Rob Pulham
Hi Rob
I like your thinking Richard:thumbs:
I measured quite a few of the "undunked" pieces (both the treated ones on the trackbed and the untreated offcuts that are waiting for the weather to improve for the next bit of the puzzle) and they are all 18.3mm - 18.4mm
The soaked pieces are in the same range - one being 18.32mm and the other 18.40mm.
Looking good so far:thumbs:
Rob Pulham
Another couple of weeks have gone by and Chris took the two pieces out of the bucket on Friday.
I measured them with the verniers this morning and all are still within the 18.3 - 18.6 range. I measured those that had been soaking and the stack of off cuts that I haven't finished with yet but haven't had any sort of wood treatment on them.
Looking good so far:thumbs::cool:
Steph Dale
It'll be interesting to see what happens to the samples in a hard frost though. If they've taken up any water at all that's when it'll become obvious...
Steph
Robin, a suggestion...
Take a piece of dry material which is about the same size as the items in the bucket, weigh the dry sample... and then weigh a wet sample (after wiping the sample surfaces) For this comparison to have any validity the pieces need to be of comparable size and the "wet" sample needs to be free of carry-out from the bucket.
