34091 Weymouth
Back in 2019 I was in my garage & found a piece of 9mm ply offcut. I thought that I am sure I could put a layout on it & so messed with some smp templates & conjured up this inglenook style shunting layout. The concept was to be a small mill complex based on Salts mill in Saltaire near Bradford.
It got shelved & forgotten about it & it's sat in the garage ever since. I dug it out & had another look at it to see if anything could be done with it. I had planned to do a new layout however money is tight & I've enough industrials to finish off or already built to make a layout with.
The layout now in my workshop In the house.
I'm going to totally change the concept to a small colliery based here in Yorkshire. I'm going to remove some track & relay it without the original cobbled area I made. I'm going to add a small extention on to the right so the wagons can go under some screens so it looks more realistic & better to operate. The canal is going to become a spoil heap & maybe a weighbridge. Basically I'm going to make it up as I go along.
I've been bashing an old airfix engine shed into a little industrial shed for the colliery.
This weekend I'm going to do a bit to get the last parts of trackwork done & wiring so it is completed in that respect. I think I've got enough timber to make the backscenes & then with a bit of luck it should start to come together & look a bit more like a scene out of the 70s.
Si
Si
