Chris Veitch
I've recently (i.e. today) posted a question on the QCAD forum regarding a problem I've got with editing attributes on referenced blocks. OK, I'm a bit impatient but it occurred to me that there's not too much traffic on that forum nowadays and someone here might have a better idea.
Basically I'm starting off with drawing templates and want to edit the attributes of (for example) the title block of a drawing border (name, date, etc.). It seems quite straightforward but I can't actually see the referenced block attributes anywhere - all I seem to be able to do is edit the original block itself, which isn't what I need at all. It looks like they should be at the bottom of the Property Editor panel but they're not there.
I realise this is a bit off topic from the usual etch design queries here but hopefully someone might be able to point me in the right direction.
Thanks in advance,
Chris
Thanks in advance,
Chris
