I have some PO wagon transfers that were supplied by Slater's Plastikard in their 7mm POW kits in the late 1990s. The instructions with the transfers say that the way to apply the transfer is to use a mix of Meths and Water to wet the transfer before applying the transfer to the model. The wisdom of WT for waterslide transfers is to apply to a gloss surface, use Microsol / Microset to aid application of the transfer and finish with matt varnish.
Does the WT wisdom for waterslide transfers apply to Methfix transfers?
Comments and suggestions appreciated.
thank you, Graham
thank you, Graham
