G3 Mid Wales Railway Brake Van/LBSC 4 ton ballast wagon.
Arty
I've made quite a few of David Mills "Sixteen Mills" laser cut 10mm kits. So a very short run of the MWR brake was sort of commisioned by a few G3 interested parties.
So the 3mm MDF sheets appeared.
The slotting and laminating worked very well, the fit being excellent.
The roof skeleton, all halving joints, again went together with no problems.
Although the parts include laminated axleguards, which work very well in the 10mm version, I decided to use Williams Models running gear, providing sprung axleboxes and Slaters wheels.
The brake gear supplied, although cut mdf, fitted very nicely.
So far I've progressed up to applying the strapping, laser cut in thin card.
Next on the list is bolt detail and handrails.
Jon Nazareth
Arty
Those look like wooden brakes to me even though one can only see the bottom section.
I've looked at the website and there is a two plank ballast wagon which I was thinking of scratchbuilding anyway. I've sent an email asking for more information. I hope it's the correct address as he has written it out rather strangely.
Jon
Steve Cook
Having seen it in the flesh yesterday, I can confirm its a very nice kit of a lovely prototype. The half lap joints in the roof construction are very impressive and allow the centre section to be removed as Rich has built it. In fact, the whole kit looks to be well thought out and accurate in terms of construction - I certainly think it will be worth keeping an eye on the manufacturers website for new products / temptations :)
Steve
Ian_T
Steve
Already doing so.... :)
IanT
geoff_nicholls
I saw the G1 versions at Peterborough, and have been trying to persuade him to blow up his early LNWR stock to G3, without much success. Unless anyone else is interested?
unklian
Bears more than a passing resemblance to one of these methinks ......
Arty
The laser scored chamfer lines were really useful, with a round needle file I took off the edge within the lines. Although MDF normally doesn’t “file” very well, the cut line gave the 45deg angle a hard edge.
I also took the ‘arris off all the sharp edges, I think it gives a better appearance for a timber built vehicle.
Arty
12E23B9B-3920-45BC-B67A-EA4C1507795F.jpeg These interesting projects just keep appearing, David Mills has cut some of his 4ton ballast wagons in G3.
Just couldn’t resist putting one together, there will be a rake of 5 eventually, but as they will need a bit of extra detailing, I’ve decided to make some patterns and cast the body strapping and bolt detailing in resin. The thought of adding all the bolt heads separately fills me with dread.
Arty
I’ve had a few issues with ply in the past, especially when it’s unsupported equally as in opens. I’ve always found MDF pretty good in that respect when it’s sealed, although the dust is a problem when sanding etc.
So I’ve done some hinge/ ironwork patterns - a bit of mouldmaking next.
Jon Nazareth
Arty
I've bought two of the LBSCR ballast wagons from David as well. I'm collecting the extra bits and pieces together before I make a start.
Jon
Arty
Jon, I've got to order a few bits to complete the 5 wagons, I see Mike W does some LBSC axleboxes.
