A Variation on a Theme
I always wondered about that concerning the GWR Toads, Simon. Never had an answer!
Brian
And that's because they didn't bother - think of all the branches without either a turntable or a triangle for a start (Abbotsbury, Bridport, Chard, Yatton-Clevedon, etc.) where that was impossible. We modellers just think one way round looks 'right'.
In the case of these early examples, where wagon turntables proliferated, they may have done, but I doubt it.
This seems sensible, pragmatic & believable, and the lack of easy turning arrangements seems to me to be a clincher.
I could go through all my picture books and count the photos, but honestly, the mojo to do so is entirely lacking. I guess that just one photo of a toad each way round would prove the point.
atb
oldravendale
Well...... If I'd thought to look at my collection of photos I'd have found quite a few examples of Toads "wrong way round" on working freight trains. That answers the problem for sure.
Brian
Brian
I have one Toad myself and it's *amazing* how many times it gets marshalled the other way round than the lamps suggest because I deliberately put them on the 'wrong' way (even by me!). None of this helps Jon with his question, however.
Spitfire2865
Not too sure about GWR, but the LNWR seemed to have an early fascination with wagon turntables since their early goods vans were one sided and they built many goods yards with banks of TTs for a lot of manual shunting.
Obviously that only matters in yards, but it probably wouldnt be too difficult if facilities were available to turn the break to the guards prefered direction.
Mike W
Not wishing to prolong this topic, break vans had windows in both ends. If they were regularly turned they probably wouldn't have needed them all, especially as the Guard could always look over the side. In most LNWR break vans the windows at the varanda end were higher because he was standing up, and lower at the other end because he was sitting down. I assume other railways were similar. Though how Chairman Moon allowed his men to sit down on the job is beyond me!
John D
Ah! Now Mike......you seem not to have read Peter Braine's book 'The Railway Moon' , it portrays the man in a totally different light to the percieved image..... recommended though there's a lot of stuff in it about share dividends...yawn!
Jon Nazareth
P.S. Does anyone have a drawing or even a picture of an early brake van side lamp? It would be interesting to know what they looked like and, if not too difficult, it may be worth having a go at making a pair.
Jon
michael mott
I'm not THAT old but I remember seeing ones like the one on the left when I was a kid the road works people used some like it. The magnifying lens was a great thing to get hold of for a 10 year old.
Michael
Jon Nazareth
Garry
Thank you for the pictures. The red one looks 'different', I'll print off the pictures of them both and give it some serious thought.
Jon
mswjr
No i do not think it is, The information i have is, The one on the right is Probably a industrial lamp made by sanderson &co, The one on the left is Probably Midland Rly tail lamp patent no 3192, These are from an auction house selling lamps, They say Probably as early lamps are hard to identify .
Peter Insole
Ahaa! I've just found the auction site and enlarged their image...
The auctioneers were talking utter twaddle!!
It is indeed an LER lamp! The number on the plate is the manufacturing date of 1931, and that ties in perfectly with the clearly visible stamping of "UD" - which was a common branding of the "UndergrounD" up until 1933, whereupon, lamps were then fully marked up as "LPTB"
I had a rusty LPTB lamp, complete with copper reservoir, and have since kept a nice "LT" branded one (post 1948) that has the later, slightly enlarged ruby glass lens. The older tank (and LTE burner) was of an identical pattern to the latter, so it was salvaged in order to create a complete and functioning lamp.
Finding any images of railway lamps, especially of the humble (non loco) variety from the mid 1800's period is a bit of a problem isn't it?! The only thing that I could find was a contemporary line drawing that showed some oddly positioned side lamps. The interesting point though, is that they were of a design that was (perhaps unsurprisingly?) influenced by the type usually used on horse drawn carriages!
Why wouldn't those early railway companies have simply turned to well established contractors that were already producing oil lamps in great quantities anyway?
Incidentally, we usually use the term "oil lamp" incorrectly. Early lamps usually burned a heavy type, such as "Colza", Rape Seed or even Sunflower oil, whereas the railway lamps that we are more familiar with should perhaps really be referred to as "spirit lamps"? Many Pre-grouping ones are found specifically plated or stamped for "Kerosene" or "Petroleum", though no such distinction was made on any later examples - presumably after that American stuff called "Paraffin" really caught on over here?!
Pete.
Peter Insole
Jon. I have been looking for something that might be suitable for you, but this is the best that I have managed to find so far:
First though, here are those odd side lamps on an L&B carriage...
You will see that they appear to be squared, with the suggestion that they are clear glass to the outside.
Significantly, they also have conical reservoirs-cum-stands as well as distinctive, and classic "double mushroom" shaped chimney tops!
Here are a couple of cropped images showing a pair of interesting lamps:
Although the proportions are rather different than those on the drawing, and they are also minus their burners and reservoirs, they do at least seem to give something of the flavour and hopefully provide some potential features that you might like to use?
Pete.
*Usual disclaimers for the use of images published elsewhere.
Jon Nazareth
Peter
That's a nice pair of lamps. Are they yours?
From looking at them, it would appear that a red lens shows forward and back and a large clear to the outside. I would assume that the small red lens would show forward.
If theses are yours, could you measure the 'square' of one side, please?
Jon
