I am reassured, but remain confused.
Hi Tim,
Can you feel my envy? By the sound of it you were already checking out MFH kits so you can hardly blame me for having laid out all that cash. Enjoy!
That's a lovely shot of the front suspension and not an image I have come across in my Googlings. If you have any more you can share please put them up.
By the way, on the Alfa there are numerous fastenings around the bodywork linked by wire. Do you know their purpose? Were the cars prone to shedding bolts and shaking to bits? I intend to add these but only have hex bolts so I may have to order some square brass rod.
Peter
Hate to say it, but if ya'll thinking these are securing bolts to stop the shackle turning (lower one) then you're mistake, they are in fact grease nipples to lubricate the shafts inside.Thank you sir!
(edit, looking back up the thread, Peter’s photo of the car head on shows the same bolts in each shackle)
I don't know how it stops rotating, but it must some how.
I've been wondering the same. I guess these rods do the trick. They block any longitudinal movement of the axle, so that the springs only allow an up and down movement. The shackles only purpose is to compensate the elongation of the springs.
Strange concept.
Michael
But would that have cost more money? I don't know about when your Riley was made but in the 1980s I did some work for a company making machines to be used for car manufacture. I can'rt remember the details but several thousand pounds extra was spent to save about 20p per car. That amounts to a lot of money on many 1ooos of cars a year.A good example on my post war Riley RME is the steering box housing. It would have been so much easier to have sold the car with a greasing point.
Mick,Hate to say it, but if ya'll thinking these are securing bolts to stop the shackle turning (lower one) then you're mistake, they are in fact grease nipples to lubricate the shafts inside.
I don't know how it stops rotating, but it must some how. My gut feeling is that the front chassis spigot fixing is splined and the shaft runs right across the vehicle as a form of anti roll bar affair.
Tim, I reckon it's a very early form or anti roll bar, the grease nipple lubricates the splines inside, stops them seizing as you note. If it's a racing car then you could adjust the left and right side to alter the suspension for say predominately left handed circuits or any other factor of which I have no idea .Mick,
Agree about the grease nipples, I believe these have been added to enable lubrication and hence the bolts seizing over time. I also think the bottom part of the shackle is fixed and can't rotate, there is a rod running transversely across the car and that it may well be splined,
Happy New Year
Tim
